TSN and OPC UA
Sebastian Hilscher | Meinrad Happacher,
Is the uniform solution coming?
TSN is intended to create a uniform standard for industrial communication. But can we trust the declarations of intent? How are manufacturers of communication components reacting to the announcements? Sebastian Hilscher takes a stand for Hilscher.
© Hilscher
Will TSN succeed in establishing a standardized solution for industrial communication in the second attempt? A few years ago, there was a lot of hype about real-time Ethernet for industrial communication. At that time, the industry was just entering the heterogeneous fieldbus world and experts believed that a standardized communication solution could be created from a hardware perspective by relying on Ethernet as the transmission medium. It quickly became apparent that the IEEE Ethernet specification did not meet the requirements of the industry. As a result, several proprietary real-time Ethernet variants were established - as was already the case in the fieldbus world. The result:
Today's 'Industrial Ethernet' is not the same as 'Industrial Ethernet'. In addition, as with fieldbuses, there were also various communication protocols that are incompatible with each other. Conclusion: Ultimately, only the cables and connectors were standardized!
The next attempt
What will the automation structure look like in the future? Will the current automation pyramid .....
© Hilscher
This is set to change this time: With TSN, the IEEE is trying to take industry requirements into account and specify a real-time Ethernet standard. This is to be used by the individual real-time Ethernet user organizations in order to have a uniform hardware basis for all future TSN-based real-time Ethernet technologies.
.... to a mixed infrastructure in which TSN plus OPC UA is used from the controller level?
© Hilscher
TSN can be seen as a modular system consisting of several sub-standards. Some have been finally adopted, others are currently still in draft status.
A brief introduction to the most important sub-standards:
1. IEEE 802.1Qbv (Time Aware Shaper) deals with the scheduling of traffic classes. This reserves bandwidths on the cable for higher-priority frames that cannot be occupied by lower-priority frames.
2) IEEE 802.1AS-rev (synchronization) is similar to the IEEE-1588 mechanism for synchronizing clocks in devices.
3) IEEE 802.1Qbu (Frame Preemption) is the splitting of low-priority Ethernet frames into fragments in order to be able to 'insert' higher-priority frames between these fragments.
4 IEEE 802.1Qca is the possibility of reserving paths through the network for individual frames.
5 IEEE 802.1Qcc describes the configuration of each participant in the network.
6) IEEE 802.1Qch is a further mechanism in addition to Qbv for establishing deterministic data transmission.
7) IEEE 802.1Qci describes how frames are recognized in the network based on time and divided into traffic classes.
8) IEEE 802.1QCB enables the duplication and transmission of a frame via additional paths in order to provide higher availability through cable redundancy.
Or will we actually have a convergent network based on a consistent, uniform communication standard?
© Hilscher
The exciting question is whether the individual user organizations that want to use TSN in the future will be able to agree on a uniform TSN profile. This is because the individual sub-standards do not necessarily all have to be used. In addition, the implementations could differ in detail, which would lead to incompatibilities in the field. This can only be avoided by using a standardized 'common' TSN profile.
While Profinet International and the CLPA have clear ideas about Profinet@TSN and CC-Link@TSN, the topic of OPC-UA@TSN in particular initially divided the camps. While the 'shaper' faction is convinced that TSN in conjunction with OPC UA from the sensor to the cloud is the right approach, other major players in the automation world only want to use OPC UA with TSN from cell level, i.e. for controller-to-controller communication and above. In the case of controller-to-controller up to the cloud, the ERP and MES levels of the classic automation pyramid merge together.
The focus of Hilscher as a technology supplier is neither only on controller-to-controller communication nor on OPC-UA@TSN. This means that Hilscher will support both CC-Link@TSN, OPC-UA@TSN and Profinet@TSN.
Beacon of hope: The IEC/IEEE working group
The IEC/IEEE 60802 working group is providing a ray of hope in the direction of a standardized TSN profile, as it is attempting to define a standardized TSN profile for the industry. If this succeeds and all the major players in automation technology join in, then the vision of the so-called 'converged' (mixed) network could become a reality. We see three possible scenarios that could occur in the next few years:
1. each user organization brews its own TSN soup and replaces its current real-time Ethernet solution with it. As is the case today, neither the hardware nor the communication protocol will be compatible with each other.
2. all user organizations adhere to the results of the IEC/IEEE 60802 working group, i.e. all solutions can be implemented with the same hardware, but the world remains heterogeneous in terms of communication protocols (software stacks and profiles). This means that the solutions remain communicatively incompatible with each other.
3. agreement is reached on a standardized communication solution consisting of a TSN profile and communication protocol. All devices can then be operated in the same network and communicate in the so-called 'converged' network.
If the user organizations agree on a uniform TSN profile, it could be possible for the classic automation pyramid to dissolve completely and everything would be connected. The right scheduling could then be used to send frames - via paths in the network - from one sensor to the cloud in the other corner of the network without affecting other traffic.
While 4-port switches are established today with Profinet IRT - with Ethercat even only 2-port devices - the advantage of TSN would be that multi-port capable switches can be used. For this reason, established switch manufacturers such as Belden/Hirschmann and Cisco are also very interested in TSN. There would be greater flexibility in terms of topology and wiring; this flexibility could be extended to include the cost-effective line structure using 2-port-based end devices. This means that topologically anything would be possible: stars, trees, rings, comb structures and even lines could be realized. Hilscher will continue to offer 2-port-capable TSN switches using the netX SoC family.
Will gigabit become mandatory?
In addition to the topology, there is another question that is always under discussion in connection with TSN: Will TSN run on Gigabit Ethernet right down to the last sensor, or will Gigabit even become mandatory?
Hilscher has the following experience in this regard: Hilscher products are now installed in many compact and temperature-critical devices using small, energy-saving multi-protocol SoCs. Customers are already reducing the power dissipation of their devices to less than 1 watt. This is necessary in order not to influence application processes in the device. Even if the technological possibilities continue to develop as a result of progress, Gigabit Ethernet technology will still be 2 to 3 times more powerful than today's Fast Ethernet-based devices in a few years' time. This would mean a knock-out criterion for some customer devices. As the market cannot do without these devices, it can be assumed that a Fast Ethernet variant (100 Mbit) will always be established alongside the Gigabit Ethernet variant in order to be able to continue using precisely these devices. - The susceptibility to interference should also not be forgotten: here too, the pros and cons of Fast and Gigabit Ethernet must be weighed up carefully.
Hilscher can already cover Fast Ethernet-based TSN today with its available multiprotocol-capable netX family. Customers who are currently using netX can therefore switch to TSN via a software update. Nevertheless, in times of vision systems - which have high bandwidth requirements - we do see a trend towards Gigabit Ethernet. In other words, many future field devices will be equipped with Gigabit Ethernet. For this reason, Hilscher is already working on expanding its netX family to include a Gigabit Ethernet variant - as before, everything from chips and software to the finished plug-in card will ultimately be available.
However, the ultimately exciting question remains unanswered: Can the user organizations agree on a common denominator? If not, we will experience a third fieldbus war! Each user organization will incorporate its own 'flavour' - such as proprietary synchronization mechanisms, its own scheduling, incompatible frame formats or summation frame procedures - into 'its own' TSN and also set its own language - i.e. its own communication protocol - on top of it.
Author: Sebastian Hilscher is Division Manager Development at Hilscher.
TSN
Arrive in reality!
Time Sensitive Networking has firmly established itself in the vocabulary of the automation industry. All well-known suppliers have started activities to evaluate or even introduce TSN. But where exactly are the goals for the use of TSN and what is...
Industry networks
OPC UA and DDS combined
To date, OPC UA and DDS have often been presented as competitors. Competitors that will both be based on the Ethernet standard TSN. - However, the key to successful automation in the future lies in a combination of the three standards DDS, OPC UA...
AS-Interface
Data pipeline ASi-5
High data width, short cycle times, improved integration of intelligent sensors and actuators using IO-Link and cloud connectivity via OPC UA - ASi-5 makes AS-Interface fit for the requirements of digitalization.
Standards
OPC UA, MQTT and co.
The Industrial Internet of Things (IIoT) covers very different areas of application. The available connectivity technologies and standards are just as diverse as the application areas. How can the right technology be filtered out in each case?
TSN
The question of licenses
Will OPC UA in combination with TSN become 'the' standard for industrial communication? What role do licenses play in this question and what part does OSADL play?
