ODVA
IO-Link devices can be integrated into EtherNet/IP
IO-Link devices can now be seamlessly integrated into CIP architectures. The ODVA has now announced corresponding further developments to the EtherNet/IP specification.
Dr. Al Beydoun, ODVA: "IO-Link device integration with CIP enables seamless communication between CIP originators and IO-Link devices."
© ODVA
The extension of the EtherNet/IP specification makes it possible to better connect IO-Link sensors and devices at the lowest level of the network with EtherNet/IP controllers and devices at higher levels of the network. "IO-Link device integration with CIP provides seamless communication between CIP originators and IO-Link devices via the intermediate IO-Link master, with all parties using existing IO-Link hardware and standards," explains Dr. Al Beydoun, President and Executive Director at the Open DeviceNet Vendors Association (ODVA).
IO-Link to CIP connectivity reduces engineering effort and simplifies the collection of data and information, resulting in a more efficient production facility that meets the demands of IT/OT convergence. IO-Link devices can now be recognized within EtherNet/IP without end users having to deal with data conversion. From the EtherNet/IP perspective, an IO-Link device is seen as a native CIP device located in a (virtual) subnet. The IO-Link master provides the CIP functions for the IO-Link device in a way that is transparent to the CIP originator application. All three types of IO-Link communication (cyclic, acyclic and events) are mapped to CIP communication types. CIP-to-IO-Link communication is possible with an unmodified IO-Link master and device specification, which is standardized by the IEC. Direct communication is made possible by conversion between CIP originators and IO-Link devices via the intermediate IO-Link master. All IO-Link devices are treated as if they were CIP connection target devices (I/O adapters) in a virtual IO-Link subnet.
Supplements for the process industry
In addition, the ODVA has supplemented the EtherNet/IP specification with regulations that define the integration of NAMUR-NE-107 diagnostics for process automation in CIP architectures. The addition of this function provides process users with industry-standard diagnostic information and allows them to benefit from the advantages of Industrial Ethernet. "The integration of NE-107 diagnostics is another step towards realizing our vision for optimizing process integration," explains Al Beydoun.
The Process Diagnostics Update for EtherNet/IP creates a CIP Process Device Diagnostics Object that provides a known, public interface to a device's current diagnostics and indicates the NE-107 status according to the NAMUR recommendation NE 107 for self-monitoring and diagnostics of field devices. The NAMUR NE 107 status signal, now available with EtherNet/IP, provides the following status information: Error, Functional Check, Out of Specification, Maintenance Required or None. The CIP Process Device Diagnostics Object expands the amount of useful data available with EtherNet/IP with the latest NE-107 diagnostic information from field devices from various vendors.
In addition to the status signal, the CIP Process Diagnostics Object displays up to 64 diagnostics of a device, such as flow, pressure or temperature status. The user can then group these as required. Vendor-specific diagnostics can also be added. Applications can now query supported EtherNet/IP field devices for changes in diagnostic status and obtain further diagnostic information using Explicit Messaging (acyclic messaging) or object-specific services. This allows all devices diagnosed with a specific NE-107 signal (e.g. maintenance required) to be retrieved with a single common service request. With EtherNet/IP, this diagnostic information can be easily transmitted to where it is needed, such as to a DCS for inspection by an operator for possible maintenance action or to an edge device for predictive maintenance analysis. "The integration of NE-107 diagnostics is designed to meet the needs of programmers, operators and maintenance technicians from both a process optimization and IIoT perspective," concludes Dr. Beydoun.
SPS 2019: Hall 5, Stand 128
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
R3 Communications
Manufacturing without cables
R3 Reliable Realtime Radio Communications presents its first series products "Echoring Ethernet Bridge" (EREB) and "Echoring System on Module" (SoM) at the SPS. They are intended to complement wired industrial Ethernet networks with equally powerful...
