KunbusMaking your own bridges
Kunbus expands the IO-Link wireless product portfolio with a Bridge Evaluation Module.
1 of 6
© Deutschmann Automation
Unigate Falcon is the latest generation of the protocol converter/gateway series from Deutschmann Automation. The DIN rail modules connect automation components with the desired fieldbus or Industrial Ethernet standard. With dimensions of 25 mm × 77.5 mm × 94.1 mm (W × H × D), the modular product series is a good 30 % smaller than its predecessor. The devices are based on ARM Cortex-M processor technology. The modules are configured via a USB interface. Free programming, for example to emulate proprietary protocols, is possible with the manufacturer's Protocol Developer Tool and the script language developed in-house. Simple scripts can be executed in just a few microseconds. Script debugging is also carried out via the USB interface. The first representative of the new protocol converter/gateway series is the 'Uniate Falcon Profibus DP', variants for Ethercat and Profinet will follow shortly.
SPS 2022: Hall 5, Stand 328
1 of 6
