Acceed
Fit for outdoor and industry
With the 'WDAP-1800AX' and 'WDAP-3000AX' from Planet, Acceed has added two dual outdoor access points to its range. The robust industrial access points for outdoor use in harsh environments work with the WiFi 6 protocol (IEEE802.11ax).
© Acceed
The WDAP-1800AX achieves a data rate of 1.2 Gbit/s in the 5 GHz band, the WDAP-3000AX up to 2.4 Gbit/s, and 3 Gbit/s in combination with the 2.4 GHz band. Both devices work with the latest standard (WPA3 SAE) for authentication and encryption. According to Acceed, simultaneous operation with radio frequencies in the 2.4 GHz band and the 5 GHz band also increases application flexibility. Thanks to MU-MIMO (Multi-User Multiple Input Multiple Output), several WLAN devices can be supplied with data simultaneously. The IP67-certified aluminum housing offers protection against dust and water and is therefore suitable for use in harsh outdoor environments at temperatures from -40 to +70 °C. Four integrated type N connections are available for high-gain antennas and are safe even in damp conditions. The 20 kV surge protection for wired interfaces protects the electronics from electrical surges.
