BE.services at the SPS 2024
SDK for the development of OPC UA devices
© BE.services
The 'eTSN Software Development Kit (SDK)' from BE.services enables component manufacturers to develop OPC UA-FX and TSN products.
The SDK is based on the Matrikon 'eFlex' OPC UA stack, which has been optimized for target hardware with low memory requirements and for 'PubSub' models. The FX standard has also been added. The BE.services SDK offers a platform-independent IEEE 802.1AS PTP stack and a test suite for the TSN network itself. The stack can be ported to any TSN-compatible hardware platform, with ports to Intel, STMicroelectronics, Texas Instruments and Renesas already available. Furthermore, it can be used either as a controller or device due to its reduced memory usage. Due to standardization, eTSN is interoperable and can be used with other third-party OPC UA FX and TSN products.
Hall 6, Stand 458
OPC Foundation
OPC UA from the cloud to the sensor
OPC UA is also establishing itself as a standard for the exchange of process data between controllers. The next step is now to extend the concepts developed for the controller-to-controller use case for the controller-to-device and device-to-device...
ISW Stuttgart
TSN in combination with EtherCAT
TSN is an important building block for convergent communication in flexible production. Mastering and integrating existing fieldbus technologies such as EtherCAT is an important part of the transition. An inventory of what is already possible.
