Bihl+Wiedemann at the Hannover Messe
ASi-5 counter module as active distributor
The portfolio of ASi-5 counter modules from Bihl+Wiedemann currently consists of different variants in protection class IP20 and IP67, each with four digital counter inputs that can be individually configured and parameterized. The ASi-5 counter module 'BWU4996' is a new addition.
The new counter module from Bihl+Wiedemann is suitable for installation in cable ducts as an active distributor thanks to its flat design with a depth of 35 mm. The module is equipped with two digital counter inputs, which can be individually configured and parameterized as two two-channel or two single-channel inputs. All ASi-5 counter modules in the range work with counter frequencies up to a maximum of 250 kHz and enable the connection of pulse counters and encoders (24 V). In addition to the flexibility in using the modules thanks to the individual parameterization and the reduced wiring effort in the field typical of ASi, additional functions ensure that many different applications can be solved with the ASi 5 counter modules. For example, the user can now choose between a 32-bit value range and fast transmission of two or four independent 16-bit counter values in just 1.27 ms. In addition to various counter functions, frequency and period duration measurements with and without filtering can also be carried out, enabling simple piece goods counting, positioning tasks or speed measurements, for example.
Hanover Fair: Hall 9, Stand H01
