1 of 11
Product innovations at the SPS 2022 - Hall 3 / 3A
Portescap, 32ECF
© Portescap
The 32ECF brushless slotted flat motor from Portescap has a diameter of 32 mm and an overall length of 17.6 mm. The 8-pole flat architecture motor uses an external rotor configuration with an air gap between the coil and the magnetic structure, which is guided radially. Its electromagnetic design has been optimized for higher performance, with an optimization of the motor regulation factor (R/K^2) by 45% compared to the standard available options. The motor also delivers a maximum continuous power of 32 W at 10,000 rpm. Customization options are available. According to the manufacturer, the motor is particularly suitable for applications that require a powerful but space-limited drive solution, such as electric grippers, laboratory automation, infusion systems, service robots and LiDar (Light Detection and Ranging).
SPS 2022: Hall 3, Stand 270
1 of 11
