News about cameras & Co.
The smart infrared cameras in the IRSX series from AT - Automation Technology are intelligent, self-contained thermal imaging systems designed for industrial use. As an all-in-one solution, the cameras combine a calibrated thermal imaging sensor with a data processing processor and a variety of industrial interfaces in a robust IP67-rated housing. A computer, special thermal imaging software or external interfaces are not required. The cameras have a range of protocols for communication with external control or automation devices, including GigE Vision, Modbus TCP, HTTPS and FTP. Software tools, standard APIs such as REST, GigE Vision, MQTT and OPC UA as well as a constantly growing number of application-specific apps support the integration and use of the cameras. Thanks to the web-based configuration interface and results display, the cameras can be set up quickly. The series includes models with different fields of view, resolutions and frame rates.
