1 of 15
New products from the drives sector
© KEB Automation
The servomotors in the DL3 series from KEB are designed for highly dynamic motion tasks. The version with the special epoxy coating 'Steel it' is particularly suitable for installation positions with direct exposure to the elements and where the surface is subject to light chemical stress from the environment. Five motor sizes from 55 to 190 mm with nominal torques from 0.5 Nm to 70 Nm are available. Four motor sizes with output torques from 5 Nm to 720 Nm are available in the special coating as servo geared motors in combination with the 1- and 2-stage planetary gearboxes for adjusting torque and speed. The range of transmission ratios extends from i=5 to i=40.
1 of 15
