Measurement technology - The winners
3rd place - Kistler
The handheld family for measuring forces from Kistler is user-friendly and can be used on site. With the help of the two mobile devices 5811A00 and 5811A01 - each with an integrated charge amplifier - users can compare and verify the data generated by the sensors used directly on the machine without having to remove the sensors first.
The two handheld devices record the measured values and visualize the measurement curve on the integrated touchscreen. In conjunction with a traceable calibration in accordance with ISO 17025, both devices can be used as a reference measuring device. In addition to its function as a measuring amplifier, model '5811A00' is also suitable for insulation tests as proof of sensor and cable quality. The '5811A01' device, on the other hand, is equipped with three channels (including for voltage input and IO-Link technology) and is used in particular for industrial multi-channel measurements.
