Innovations in drive technology
With the 'Roba-torqcontrol' module, Mayr Antriebstechnik has developed an intelligent solution with which adaptable braking reactions are possible and machines can be brought to a defined standstill. If the module is used in a closed-loop system, defined deceleration ramps can be run; this means that the machines can be braked gently and according to requirements. The 'Roba-brake-checker' module is used to monitor the brakes. 'Roba-torqcontrol' shares the monitoring function and can also control brakes. Both modules work without a sensor. Instead, they analyze current and voltage and thus detect the movement of the armature plate. This is how they 'know' what state the brake is in. In addition to the switching status, the modules can also draw conclusions about temperature, wear and traction or traction force reserve.
