1 of 4
Electromechanics - The winners
Computer&Automation "Products of the Year 2024" - Electromechanics - 3rd place: Weidmüller
© Weidmüller
3rd place - Weidmüller
The Klippon Connect terminal blocks with lateral Push In connection from Weidmüller are a solution for safe wiring in narrow distribution boxes. The terminal blocks combine the advantages of screw connection technology with the operation of Push In technology. They enable tool-free, clear wiring without a protruding bending radius. The side entry of the conductors into the terminal reduces the installation height and increases connection reliability without having to bend the cable. According to the manufacturer, this enables clear and space-saving wiring. Thanks to the clear arrangement of the side conductor entry, the terminal blocks are accessible for test systems even when wired. At the same time, the push-in connection provides a vibration-proof, gas-tight and permanently reliable connection. If the conductor needs to be disconnected again, simply press the pusher on the top of the terminal block. In addition, the markings and functional areas are clearly visible - even when wired.
1 of 4
