Drive technology - The winners
3rd place - Lenord+Bauer: High-resolution built-in encoders with digital interface
Lenord+Bauer is expanding its portfolio of digital 'Minicoders': With the MHSSI interface (Mitsubishi High Speed Serial Interface), they offer a resolution of up to 67,108,864 positions per revolution (26 bit). Compared to the classic 1 VSS interface, the use of the MHSSI interface enables direct integration of the bearingless encoders into Mitsubishi CNC systems. There is no need for an additional signal converter box, wiring is simplified and additional connectors as potential sources of error are eliminated. The resolution of the mini-encoders has been increased 16-fold compared to the first generation. This is available up to a maximum speed of 100,000 rpm. In addition to the speed and position, the built-in encoders also record the temperature on the b-side bearing, which enables the condition of the bearing to be monitored during warm-up and spindle operation under load. The additional transmission of warning and error messages via the digital MHSSI protocol supports condition monitoring.
