"ChatGPT in the industry" - Part 6
Dr. Hans Egermeier | Meinrad Happacher,
Support with architecture and conception
The generation and processing of natural language is the paradigm discipline of AI in the form of Large Language Models (LLMs). But how suitable are LLMs for the generative generation of useful results in the architecture and conception phase?
© Pixabay
One of the main challenges in architecture design is to break down complex systems into clearly defined, modular components depending on the functional and non-functional requirements. Generally speaking, LLMs can act as intelligent assistants by helping to analyse textual descriptions, structure requirements and provide suggestions for the modularization and structuring of the architecture. In this way, LLMs can help to outline the initial architecture and create architecture documents efficiently.
>> Read parts 1 to 5 of the article series "ChatGPT in the industry"
A particular challenge is that, in addition to the textual description, diagrams are usually also used for the architectural representation and documentation. However, since the LLMs available today cannot generate these directly and no usable results can be expected from the AI image generators available to date apart from pretty pictures, a little trick has to help: By using text-based diagrams such as 'PlantUML', 'Mermaid' or similar, LLMs are able to provide support in this respect as well. They are therefore not only dependent on pure text information.
General prompt engineering rules
In order for the use of generative AI for conceptualization and architectural design to be successful, the rules for prompt engineering described in the previous articles also apply here. To summarize:
  • Use generally good prompt wording: clear and specific instructions, separators and structured output formats.
  • Use prompt techniques that help to increase the "depth of thought" and "reasoning" of LLMs: For example, chain-of-thought, tree-of-thought or step-back prompt techniques.
  • Using prompting techniques with format templates and content examples such as the few-shot prompting technique.
  • Compiling the decisive local contexts either manually or with the support of an intelligent local search system called RAG (Retrieval Augmented Generation), which is also frequently used with chatbots.
Proven architectural design processes
There are many ways to achieve a good software architecture. Two well-known and proven approaches are the 'arc42' and 'C4' methods for documenting and visualizing software architectures, which we can also use for support with generative AIs.
arc42 is a freely available, very well-structured template and is therefore not a pure method in the true sense of the word. This template is a framework for documenting software architectures, which is divided into twelve sections to cover as many architecture-relevant aspects as possible. It begins with an introduction and objectives, followed by boundary conditions and a context definition. Sections such as the building block view, runtime view and distribution view enable developers to describe the architecture comprehensively and make it comprehensible. The perspective on risks and technical debt as well as a glossary conclude the template.
Thanks to the good structure and the various well-described predefined views, arc42 offers an excellent starting point for using generative AI to pre-formulate the individual sections in conjunction with your own given information and intentions.
In contrast to arc42, the C4 modelling method is not a document template, but an approach to representing the architecture of software systems based on the visualization of different levels of abstraction. It comprises four levels, each of which looks at a specific aspect of the software architecture in more detail: Context, Container, Components and Code. Starting at the highest level (Context), the system is shown in relation to external systems and users, followed by a more detailed representation of the main applications and data storage in the Containers diagram. The third level (Components) further breaks down the containers into their main components and their interactions, while the Code level finally shows the implementation details, such as classes or interfaces.
Figure 1: The ChatGPT task: to create a retrofit-capable IIoT kit for temperature monitoring of production facilities. This involves additional sensors, data loggers, a transmission unit and a PLC-capable independent dashboard.
© talsen team
The systematic decomposition of larger problems into the respective different levels of abstraction is a proven tactic for working productively with generative AIs. As described in the previous article, the principle of "coarse to fine" has also proven to be very useful in supporting the formulation of requirements according to the abstraction levels from behavior-driven software development (BDD). This makes it easy to regulate the required depth of thought of the LLMs. If the results become too fuzzy and the formulations of the LLMs are no longer useful, this is a strong indication of either the lack of relevant context or too large a jump between abstraction levels, resulting in too many unseen and unknown assumptions on the LLM side. This in turn most likely results in a higher manual correction effort of the LLM answers.
Using the example of the current top model gpt-4o from OpenAI (accessible via the paid account of ChatGPT), we take a concrete look at how useful the tactic of "coarse to fine" or "divide and conquer" is for the use of generative AI using the architectural description of a simple IIoT example(Figure 1):
The example of interlinked production plants can be approached with two architecture descriptions:
  • Variant 1: The creation of an architectural image or diagram using a simple text and image description.
  • Variant 2: The systematic creation with C4 using a simple text and image description.
Variant 1 - a method that is too simple
The use case demonstrates that LLMs can generate very different result qualities depending on the prompt. If we use the image of the IIoT example - which can be inserted using drag&drop or copy&paste - with the prompt "Create the component diagram of the required application based on the given description", this is literally too short-sighted for the LLM. The results will be disappointing and unusable in most cases without further specifications.
Variant 2 with the C4 method
Figure 2: Robust IIoT application - System Context Diagram. The C4 system and the context diagram.
© talsen team
If, on the other hand, we use a slightly more elaborate prompt and the C4 method as the common thread for an architectural design, we can expect much more useful results. For the following example, we work in a single chat in order to be able to use the content of the previous answer for the next prompt. In the context of productive work, each result would have to undergo a separate review process, be corrected and only then the next stage with the improved context would be requested in a fresh chat. Our shortened prompt recipe for the example is as follows:
Prompt 1 - initial analysis and extraction of the information contained in the image:
IIoT image + text: "Analyze the sketch. Create a list of functional requirements that you can derive from the image. Create a list of non-functional requirements that you can derive from the image. Based on the functional and non-functional requirements, create an architecture proposal for a modular, expandable and easily maintainable software application."
Result: Contains the description of the requested content points. Listing omitted due to lack of space.
Prompt 2 - Representation of the highest level of abstraction; C4 system and context diagram (Fig. 2):
"Please create a C4 System Context Diagram for me based on the analysis results. Please generate the C4 Context Diagram with PlantUML."
The result is an amazingly good and detailed proposal. Please note: initially the same information was used as in our simple prompt. If you want to reproduce the experiment, you can visualize and check the PlantUML instructions contained in the LLM answer yourself online using a free PlantUML server.
Figure 3: Robust IIOT application - backend API component diagram. The component view of the backend API of the IIoT application.
© talsen team
Prompt 3 - first detailing in C4 as a container diagram:
"Please now create the C4 container diagram for the IIoT application based on the previous results."
Result: Representation of the large technical building blocks of the application (omitted due to lack of space). However, this is an important step in the practical architecture description that must not be omitted.
Prompt 4 - second detailing in C4 as a component diagram (Fig. 3):
It is important to always set a special focus from this level at the latest, so that the results are not diluted. Here with a focus on the backend of the IIoT application.
"Please now create the C4 component diagram of the backend API container based on the previous results."
Result: Thanks to the well-controlled step width between the abstraction levels, this result is also a surprisingly well-developed and detailed proposal. The technical decisions made by the LLM are unsupported assumptions. If we had included technical constraints as context in the prompt, these would be taken into account in the component diagram.
Figure 4: The robust IIoT application, shown as a code diagram of the Alert Service.
© talsen team
Prompt 5 - third detailing in C4 as a code diagram (Fig. 4):
It is also important to set a focus in this step.
"Please now create the C4 code diagram based on the previous results. Select the Alert Service component of the backend API container for the diagram to generate an example of a deeper code level."
Result: As with the previous steps, it should be noted that this result could be generated without any further external information. The only content specification is still the initial sketch, which enables useful results even down to the code level thanks to the targeted decomposition.
The quintessence
The use of generative AI methods in forward architecture design and software design offers interesting advantages. In the example shown here, an initial architectural design can be derived by using comparatively simple prompts in combination with the proven C4 method and also with relatively little input information.
The author: Dr. Hans Egermeier is Managing Director of talsen team.
© talsen team
In our next post, we will look at how LLMs can help existing software to recognize architectural patterns and document and improve backward-looking architectures.
Fraunhofer IMS
Funding project on embedded AI
The "Edge AI Platform" project is entering its third round of funding: three Fraunhofer Institutes are further developing the platform to version 3.0 in order to provide companies with even more efficient access to embedded artificial intelligence...
