Products of the year 2020/2021Readers' choice: Who are your favorites?
Smart, innovative, trend-setting - that's what the automation industry was like again this year! We have nominated 96 products in twelve categories and put them forward for your vote as "Products of the Year". Which are the most innovative and useful products for you?
3 of 11
2 Micro-Epsilon
© Micro-Epsilon
The laser scanners in the Scancontrol30xx/BL series from Micro-Epsilon are designed for dynamic measurement tasks that place high demands on resolution and accuracy. They are available with 25 and 50 mm measuring ranges (along the laser line/X-axis).
The devices with a blue laser line deliver calibrated 2D profile data at around 5.5 million points per second and generate up to 2048 measuring points per profile. The 'Scancontrol 3060-25/BL' models achieve an X-resolution of around 12 µm. The laser profile scanners are also designed for fast processes with a profile frequency of up to 10 kHz. Thanks to the high-dynamic range mode, the sensor generates precise measurement results even on inhomogeneous surfaces, according to the manufacturer.
The measured values are output via Ethernet or RS422 interface. The sensors can be integrated into Profinet, Ethercat or Ethernet/IP control systems via the optional 'Scancontrol Gateway'.
For tuning.
3 of 11
