Products of the year 2020/2021Readers' choice: Who are your favorites?
Smart, innovative, trend-setting - that's what the automation industry was like again this year! We have nominated 96 products in twelve categories and put them forward for your vote as "Products of the Year". Which are the most innovative and useful products for you?
6 of 11
5 Autovimation
© autoVimation
With its positioning system,Autovimation offers a compact solution for the precise alignment of camera protection housings. The core of the modular system consists of fine positioning axes with a 150 mm stroke, which ensure high adjustment accuracy with their hand crank-operated feed of 1.5 mm per revolution.
According to the supplier, the axes are slimmer than conventional models, as their spindle channel with dovetail profile also serves as a sliding guide for the slides.
For free positioning of the cameras at any angle, the accessories of profile rails, rotary axes, angles and interchangeable positioning tables for vertical or axis-parallel mounting enable multi-axis arrangements to be set up quickly. No adapter plates are required for this, as all of the manufacturer's components use standardized profile systems - camera housings or additional axes can be mounted directly to the positioning tables using dovetail clamps.
For coordination.
6 of 11
