Products of the year 2020/2021Readers' choice: Who are your favorites?
Smart, innovative, trend-setting - that's what the automation industry was like again this year! We have nominated 96 products in twelve categories and put them forward for your vote as "Products of the Year". Which are the most innovative and useful products for you?
5 of 11
4 Matrix Vision
© Matrix Vision
For use in harsh environments, Matrix Vision offers a waterproof version of the 'mvBlueCougar-X' industrial camera with the IP67C option. The C in the name stands for compact, which is the main advantage.
The waterproofing has been integrated into the standard housing so that little installation space is required. The plug-in connections can be screwed on. There are two options for sealing the lens - either a standard lens is used in conjunction with a protective tube (available in lengths of 40 mm, 71 mm and 100 mm), or waterproof IP67 lenses are used. Kowa has added the latter to its portfolio as the BAM LS-VS-008 waterproof lens series.
Thanks to the various equipment options, the mvBlueCougar-X Gigabit Ethernet camera family covers the majority of possible application areas, according to the provider. The camera has various smart features such as flat field correction, color correction or white balance, which can be carried out directly on the camera.
To the vote.
5 of 11
