Wago at the SPS 2023
Narrow multi-channel for more packing density
The electronic circuit breakers from Wago for 24 V(DC), with four 4 (787-3664) and eight (787-3668) channels, are used in all industries with sensors and actuators and other electrical loads in the 24 V(DC) range.
© Wago
These include, for example, the process and manufacturing industry, automotive production and energy technology. With their compact width of 32 mm, the multi-channel circuit-breakers are the narrowest ECBs available on the market, according to manufacturer Wago. When using the 8-channel circuit-breaker, this results in a space saving of 50% compared to eight single-channel circuit-breaker modules. The 4-channel circuit-breaker is available in the same width of 32 mm. This means that 4-channel circuit-breakers can also be replaced by 8-channel circuit-breakers for extensions. Each ECB channel can be safely operated and the respective tripping current set via an LED-illuminated on, off and reset button as well as a potential-free signaling contact. Pre-wiring is possible thanks to plug connectors with mismating protection.
Hall 7, Stand 230
Wago
From production to the car wash
The data in industrial production is already available, but still needs to be brought together. The IIoT helps with this. The prerequisite for this is open automation. A concept that not only provides a decisive (competitive) advantage in industry.
Partnership
Wago relies on Bosch Rexroth
Wago will be the first system and technology partner to use the real-time capable, Linux-based operating system 'ctrlX OS' from Bosch Rexroth on future controllers in the medium and high performance classes.
Wago
Strengthening cyber resilience
In view of the increasing damage caused by cyber attacks and EU directives such as the CRA, holistic cybersecurity is becoming indispensable. Dr. Christopher Tebbe, security expert, and Kilian Fröhlich, manager in OT security consulting, explain how...
Wago / Radiflow
Partnership for OT security
Wago, a provider of electrical connection and automation technology, and Radiflow, a specialist in OT cyber security, are entering into a partnership and pooling their expertise. Together, they want to strengthen resilience against potential cyber...
In focus: Agriculture
The e-paper of issue 05/2024
Strategies for the future are one of the topics covered in the current issue of Computer&Automation. Read about the reforms that associations are demanding from politicians, the opportunities offered by technologies such as ChatGPT and SPE and...
