econ solutions
Rolf Wagner | Andrea Gillhuber,
Energy efficiency for climate-neutral production
It is becoming more important for manufacturing companies to reduce CO2 emissions. This should start with improving energy efficiency. After all, every kilowatt hour saved does not have to be generated or substituted. Energy and production data show starting points.
© econ solutions
The greatest potential for reducing energy consumption in manufacturing companies lies in production. There can also be significant efficiency potential in air conditioning and lighting in buildings. But every company is different. That's why transparency about energy flows and consumption is needed first. This is the only way to determine the status quo, define efficiency measures and prevent bad investments in ineffective measures. In addition, the effects of each measure can be measured and quantified immediately so that energy efficiency can be increased in a targeted and sustainable manner.
Most companies already have measurement technology in use, but many read these manually and enter them into Excel or similar tools for evaluation. This is not only time-consuming, but also insufficient for systematic energy management. This is because the measurement intervals are usually too long, the data quality is inadequate and the evaluation options are not meaningful enough.
An energy management system automates this process: the measurement data is transferred via the company network to software that visualizes the data through evaluations and reports. They make efficiency potentials immediately visible. In addition, limit values can be defined so that alarm messages are automatically sent to those responsible if they are exceeded or not reached.
Example of an energy management system
The ABC analysis shows the largest consumers and is therefore an ideal starting point for efficiency measures.
© econ solutions
At Fried Kunststofftechnik, energy management is also making an important contribution to the company'sCO2-neutral production since 2021. Fried has been ISO 50001-certified since 2014 and has successively expanded its energy management system since then. The company now records the energy data of its entire production with 142 measuring points. The 'econ sens3' from econ solutions is used as the energy and power measuring device. It can be installed in a space-saving manner and measures the central parameters of electrical energy. As it comes with all standard interfaces, including Ethernet, Modbus TCP / RTU as well as analog and digital signals, data from different measuring devices can be integrated in a manufacturer-independent manner and passed on to higher-level systems. Fried uses this to record heat and air volumes as well as temperatures. All data flows into the econ4 energy management software. Gas and water consumption are entered there manually every month. The software provides all standard reports, such as load profile and consumption, but also management and special reports, for example ABC analysis, spectral analysis, cost andCO2 reports.
The first step is usually to determine the largest consumers. The software not only displays these as bars in the ABC analysis, but also uses a pie chart to show the size of each consumer. The evaluations made it clear to Fried how energy can be saved in the automatic painting process by optimizing the control parameters without any loss of quality. The situation was similar for the compressed air system with frequency-controlled compressors: Here, the company was able to use the analyses to determine the minimum system pressure required. Thanks to the energy management system, the company was able to reduce its energy requirements in areas that were not previously on its radar.
Energy management software as a data hub
An energy management system brings transparency to energy consumption and energy flows in the company. The data from measuring devices from various manufacturers can be read out and evaluated using the econ4 software.
© econ solutions
All existing data sources can also be integrated into the energy management system at software level, for example from other company systems (e.g. MDE/BDE, ERP). All energy types (electricity, gas, water, heat, compressed air) and status data such as temperature or pH value can also be integrated automatically or entered manually.
Fried Kunststofftechnik has linked the ProSES MDC system with econ4. This makes it possible to determine order-related energy values and create a fact-based foundation for more precise calculations. "The higher the energy prices are, the more important it is to take them into account appropriately in quotations," explains Dr. Andreas Tewald, Energy Management Officer and Head of Work Preparation, Facility Management, Maintenance/Maintenance at Fried. He adds: "There is another advantage of integrating ProSES into econ: the view of our processes has expanded so that we understand them even better, for example by comparing different processes on the individual machines."
The linking of energy, production and other data also enables the automated determination of Energy Performance Indicators (EnPI). Users have also recognized that the data can be used not only for energy management, but also for system monitoring: if consumption is higher or lower than usual and there is no explanation for this, the next step is to troubleshoot.
By looking at the reports, users gain insights that are not primarily related to energy efficiency. This was the case at Fried Kunststofftechnik when the energy consumption of the paint shop increased disproportionately. The search for the cause led to a dirty filter. Fried now uses this fact to replace the filters as required based on the measurement data. Twice a year, the company uses the evaluations to determine the overheads for the production machines and adjust them if necessary.
Rapid amortization through subsidies
The author: Rolf Wagner is an authorized signatory and Head of Sales at econ solutions.
© econ solutions
An energy management system can involve high costs, especially if extensive measurement technology is required. If existing measuring devices, meters, probes and sensors can be integrated, the necessary investments can be reduced. Energy management systems are also supported by extensive subsidy programs. One of the most important is the EEW (Federal Subsidy for Energy and Resource Efficiency in the Economy). Under 'Module 3: Measurement and control technology, sensors and energy management software', companies can receive up to 40% of eligible investments for the purchase, installation and training, and small companies even up to 50% - up to 15 million euros per project. Experience from numerous projects also shows that an energy management system pays for itself after just a few months thanks to the savings it achieves. In this way, climate protection and economic efficiency go hand in hand.
