Insulation fault locators
Quelle: Bender | Inka Krischke,
Connection via plug-in terminals
The EDS440 insulation fault locator from Bender is specially adapted to the additional functionality of the 'iso685' insulation monitoring device.
© Bender
The 'iso685-D-P' version is equipped with the locating current injector required for insulation fault location and the operating menu for setting the EDS440 has been expanded and adapted. An automatic bus scan for detecting the connected insulation fault locators and individual text input for the alarm messages make it easy for the operating personnel to use. The connection is made using plug-in terminals, which are available either as screw or spring terminals. The device series basically comprises four variants: EDS440-S and EDS440-L for use in main circuits with a response value for the generated test current of 2 to 10 mA as well as EDS441-S and EDS441-L for use in control circuits with a response value for the generated test current of 0.2 to 1 mA.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
