Terminal blocks
Quelle: Weidmüller Interface | Inka Krischke,
Save time during engineering
Klippon Connect is the name of Weidmüller's terminal blocks and process-supporting services, which are designed to enable time savings of up to 75% in engineering, consistently error-free wiring and faster marking processes.
© Weidmüller Interface
Two terminal block programs are available - an application program and a universal program. Which range is the right choice depends on the respective requirements. The universal range is designed to be function-oriented. For frequently recurring applications, such as control current distribution or signal wiring, the application program is ideal, in which product functions are specifically arranged or omitted. The application also determines the respective connection technology, screw or spring connection. The screw connection is designed as a clamping yoke or bolt connection, the spring connection in push-in or tension clamp technology. The 'Weidmüller Configurator' (WMC) is available for designing the planning process. The web-based software solution provides step-by-step support for selecting and assembling terminal blocks and accessories. The integrated plausibility check ensures only permissible configurations - any errors are automatically corrected.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
