Tsubaki cable towing
Minimized abrasion
In the gliding operation of cable drag chains, abrasion in gliding operation as well as oscillations and vibrations are part of the status quo. A module mounted on the carrier provides a remedy by quickly and controllably placing the upper run on the lower run.
© Tsubaki cable towing
If the unsupported length of cable drag chains is exceeded, they are usually used in a version that slides on top of each other. In this arrangement, it is advisable to reduce the height of the carrier connection - this reduces the mechanical load in push operation for long travel distances and increases the service life of the systems. At the same time, the energy chain or the arc projection is extended. In this case, Tsubaki Kabelschlepp uses so-called rKR links at the driver connection, which ensure a minimum arc length thanks to their S-shaped arrangement. This also ensures that the minimum bending radius of the guided cables is maintained in every position.
Wear due to point loading
Behind the pivoting driver connection of gliding cable carriers, abrasion occurs at certain points, resulting in maximum wear and a significantly reduced service life of the cable carrier.
However, due to the deeper attachment connection, there are further requirements that must be taken into account in the practical design of this area. For example, the service life of gliding energy chains is primarily determined by the wear between the chain bands. This is why modern energy supply systems are equipped with glide shoes made of highly abrasion-resistant plastic. However, abrasion problems can still occur in the area behind the driver, which goes into gliding operation first. To prevent this, the connection must be optimized.
A so-called swivel or oscillating driver connection is very often used in order to make the cable carrier slide as quickly as possible by means of a short unsupported length. However, this results in the chain sagging after the carrier, which only leads to punctual contact. This is where maximum wear sets in and significantly reduces the service life due to the point load in this area. As a remedy for this effect, a support plate is often used on the carrier. Despite the increased design effort, however, this measure only helps to a limited extent.
The GO module from Tsubaki Kabelschlepp prevents punctual abrasion behind the driver connection by immersing the lower run of the chain in the guide channel at a very shallow angle over a large area.
Tsubaki Kabelschlepp has developed the GO module for this problem, which guarantees a minimum arc length in the push end position on the one hand and ensures optimum gliding operation of the energy chain with minimum wear behavior, particularly in the driver area, on the other. The GO module is a standardized arrangement of chain links that are specially designed for an optimum attachment of flights at a fixed connection height. In the push end position, the chain links are designed so that they enter the guide channel as early as possible.
The GO module distributes the load caused by abrasion over a larger wear volume at the start of sliding operation, thereby extending the overall service life of the cable carrier.
The special design of the GO module ensures vibration-free operation and also prevents punctual abrasion of the cable carrier due to slack. This is achieved by the lower run of the chain plunging into the guide channel over a large area - at a very shallow angle. The load caused by abrasion is thus distributed over a larger wear volume, which increases the service life at this point many times over.
Another advantage of the GO module comes into play, particularly at high accelerations and long travel distances: the special arrangement ensures optimum transmission of the drive force in the direction of the upper run without additional auxiliary measures, thus minimizing the necessary thrust of the chain. The reduced and firmly defined driver connection height also significantly minimizes the bending load on the cable carrier.
Applications with high travel speeds
Thomas Ameis is Senior Product Expert Cable Carrier Systems at Tsubaki Kabelschlepp in Wenden-Gerlingen.
Due to its improved service life properties, the GO module is particularly suitable for applications with high travel speeds of over 3 m/s and a high number of travel cycles. Practical long-term tests have shown a service life of up to 150,000 sliding kilometers. This makes the module equally suitable for automation systems, gantry robots and system installations as well as for crane technology and applications in the field of storage and handling technology.
The GO module can be used universally in all sizes for 'Basic' and 'Vario-Line' cable drag chains. The range covers internal heights from 26 mm to 87 mm with widths from 25 mm to 800 mm. The cable drag chains with GO module can be designed and dimensioned using the 'OnlineEngineer' online tool.
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
