Harting at the SPS 2022Space-saving plug connectors
The "Han 1A" plastic connector (pictured left) from Harting has a compact, robust and universally applicable rectangular connector system for transmitting data or signals in Industry 4.0.
3 of 7
© Escha
Escha has developed a product family with overmolded connectors based on the Deutsch-DT design, in which the self-constructed contacts and contact carriers are overmolded in a one-shot process. This avoids long supply chains. The previously available 2-, 4- and 6-pole versions as sockets and plugs as well as connection and connection cables are now joined by 3-, 8- and 12-pole versions as well as LED versions.
Various modification options are available on customer request, such as connecting cables with M12 connectors on the B-side. Thanks to this wide range of variants, the overmoulded connectors in Deutsch DT design are replacing the pre-assembled variants that were previously used and also offer a compact alternative to valve connectors. The DT connectors can optionally be equipped with a threaded outlet for protective conduits. The protective conduits offer additional protection against stone chipping and coarse soiling. All products comply with IP67, IP68 and IP69.
SPS 2022: Hall 10, Stand 321
3 of 7
