8 of 25
RLFZ-M series from Icotek
© Icotek
The RLFZ-M series from Icotek is a further development of the RLFZ EMC in-line foot for space-saving installation of MSKL shield clamps with a large clamping range. This makes it possible to intercept cables from 3 to 12 mm with a shield clamp size and relieve them against tension (DIN 62444). The shield clamps are offset in two rows and, according to the supplier, are extremely space-saving thanks to the optimum arrangement of the clamps. The row base is screwed directly onto the mounting plate and ensures that the clamps are firmly seated. Ten different bracket lengths are available, meaning that the row base can be adapted to customer requirements.
8 of 25
