Product presentationsNews from electromechanics
Connectors, cable glands, cables and wires - there are always numerous innovations for industrial users when it comes to electromechanics. Computer&AUTOMATION has summarized a selection of current products in a series of pictures.
5 of 15
Fiplock One Aspa-HV end, feed and suspension adapter from Fränkische Industrial Pipes
© Fränkische Industrial Pipes
Fränkische Industrial Pipes is launching the Fiplock®One Aspa-HV termination, pull-in and suspension adapter. The closed adapter is mounted on the end of the 'Fiplock' corrugated conduit and thus protects the cables and conduits inside from dirt or mechanical influences, for example. An eyelet at the connection end of the adapter allows the sensitive cables bundled in the corrugated conduit to be hung on a hook or similar device for transportation. Alternatively, the hole can be connected to a pull-in cable in order to pull the preassembled corrugated conduit into a system or install it. Aspa-HV meets all protection classes from IP66 to IP69, is classified in fire class V0 and fire hazard level HL3, is self-extinguishing and does not spread fire. The adapter fits all corrugated conduits with nominal widths of 23 and 36 and with a fine (F) or coarse (C) profile. It is made of modified PA6 and can withstand temperatures from -50 to +120 °C.
5 of 15
