Product presentationsNews from electromechanics
Connectors, cable glands, cables and wires - there are always numerous innovations for industrial users when it comes to electromechanics. Computer&AUTOMATION has summarized a selection of current products in a series of pictures.
6 of 15
Power supply cables from Hradil special cables
© Hradil Spezialkabel
With the HighPerformance 43 x 1.5 mm2, Hradil Spezialkabel is presenting a robust, reeling and drag chain-compatible power supply cable that is particularly suitable for demanding outdoor applications in extreme climatic conditions thanks to its extended operating temperature range between -50 and +90 °C. The cable is UV, ozone, oil and diesel resistant, resistant to coolants and lubricants and has UL and cUL approval. It has been tested by the VDE in accordance with DIN 60811. With a tensile strength of up to 4000 N, a design for at least 1.2 million bending cycles with extremely tight bending radii of up to 200 mm and extreme accelerations of up to 5 m/s, the cable is well equipped for applications with very high mechanical stresses. It has a three-layer design with 43 x 1.5 mm2 cores and yet only has an outer diameter of 22.9 mm. Differently defined taping and shielding in all three layers with PTFE foils, PES fleece and aramid provide strain relief as well as shielding.
6 of 15
