Product presentationsNews from electromechanics
Connectors, cable glands, cables and wires - there are always numerous innovations for industrial users when it comes to electromechanics. Computer&AUTOMATION has summarized a selection of current products in a series of pictures.
1 of 15
1_Miniature connector RST Micro from Wieland Electric
© Wieland Electric
With the RST Micro, Wieland Electric is launching a miniature connector with a diameter of less than 15 mm. The 2 to 3-pin connector, specially designed for low-voltage applications, is optimized for the interface between voltage or current sources and LED modules. It is also suitable for industrial environments; its rated data means that mains applications are also no problem. Four mechanically and color-coded plug connections ensure safe separation of different applications. Like the larger members of the 'RST' product family, the miniature connector also simplifies installation. The fully pluggable system - from the distributor to the electrical device - consists of factory-assembled and tested components. The miniature connector is also available with an optional water stop. An internal sealing system prevents moisture from penetrating and prevents damage to the entire installation.
1 of 15
