Sigmatek at the SPS 2023
Andrea Gillhuber,
I/O electronics with X possibilities
"An I/O system as versatile as our customers," is how Sigmatek Managing Director Alexander Melkus describes the 'ready to use' I/O system 'X-DIAS' from Sigmatek, which celebrated its premiere at the trade fair.
Alexander Melkus with X-DIAS
© Uwe Niklas / Computer&Automation
This can either be mounted on the top-hat rail or, for higher quantities, simply integrated into the OEM PCB design and plugged onto the rear. The bus connection is already integrated in the I/O modules. The standard bus systems are available for communication with the controller, including Industrial Ethernet and Varan bus. The X-DIAS modules can be mounted on the top-hat rail as standard. Function-oriented connectors with +/- signals for each input and output ensure a clear overview during wiring and commissioning.
The I/O system can be integrated into customer-specific designs for series production of machines with higher quantities. The basic modules can be simply plugged onto customized wiring boards - on the rear. This allows the control cabinet to be used in three dimensions and reduces the footprint. In this version, fuses, cut-off relays and the necessary intermediate wiring can be integrated on the OEM board, for example. Pre-assembled cable harnesses reduce the wiring effort.
The X-DIAS system can be combined or extended with the S-DIAS and P-DIAS automation system (IP67). In the LASAL engineering tool, applications can be designed graphically using object-oriented programming.
Weidmüller
Joachim Herz Foundation invests
The Hamburg-based Joachim Herz Foundation acquires a stake in Weidmüller as part of a capital increase and thus holds around 20% of the shares in the family-owned company. The commitment is aimed at long-term corporate development and accelerated...
Wago / Radiflow
Partnership for OT security
Wago, a provider of electrical connection and automation technology, and Radiflow, a specialist in OT cyber security, are entering into a partnership and pooling their expertise. Together, they want to strengthen resilience against potential cyber...
Wago
Group continues to grow in 2023
The Wago Group is growing for the third year in a row and will achieve sales of EUR 1.37 billion in 2023. This means that the manufacturer of electrical connection and automation technology has increased its turnover by 2.2% compared to the previous...
