Conec
Yvonne Junginger,
Hybrid connectors with IP67 protection class
The hybrid connector system from Conec combines and transmits the power supply and data transmission in accordance with Cat 5 via a specially developed hybrid cable.
© Conec
This single-cable technology corresponds to modern connection and interface wiring. With the angled B23 hybrid flange, it is possible to equip servo drives with an output of over 20 kW with a single-cable solution. Common to all sizes is the separately shielded four-pole data element for the transmission of Industrial Ethernet in accordance with ISO11801 Class D or signals with currents of up to 4 A.
The connector is locked with a bayonet quick-release fastener, so there is no need to use a torque wrench to tighten the screws. A quarter turn ensures a secure connection and IP67 protection. The bayonet can only be locked when the hybrid connectors are fully inserted. According to Conec, this reduces the risk of failure due to connectors that are not fully mated or have a defined screw connection.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Tsubaki cable towing
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
