Provertha
Flexibly customizable plug-and-play system
Provertha has developed a fully shielded distribution system for M8/M12 cabling that allows several cables to be combined via circular connectors so that signal and power can be transmitted over long distances via a single cable.
The M8/M12 distributor from Provertha is a flexibly adaptable plug-and-play system with which the cabling can be specifically optimized depending on the application. It is based on standard components for pluggable M8, M12 or direct cable connection and is suitable for both industrial and railroad applications. The solid full metal housing enables shock, vibration and torsion-proof connection and integration of the connector cables into the distribution solution. Protection class IP67 can be optionally realized by potting.
