Phoenix Contact
Fast connection
In addition to the XTV terminal blocks with side conductor routing, the first terminal blocks with front Push-X connection are now also available from Phoenix Contact.
The XT portfolio consists of feed-through and multi-conductor terminals as well as functional variants for the use of disconnect blades, plug-in fuses and components. According to Phoenix Contact, the new Push-X technology increases the efficiency of control cabinet wiring. All conductor types and cross-sections can be connected even faster manually or automatically. Direct wiring is carried out without tools and without significant effort thanks to a pre-tensioned contact spring. By lightly tapping the release surface inside the clamping chamber, the contact spring is released and the conductor is securely and permanently contacted. As with push-in technology, the connected conductors are released by pressing the orange pusher; the contact spring is pre-tensioned for a new wiring process.
