Multi-IO modules
Quelle: Sigmatek | Inka Krischke,
Digital and analog in one module
The IO 011 multi-IO module adds a mix module to the S-Dias control system from Sigmatek. With a width of just 12.5 mm, 14 digital I/Os and two analog inputs provide a variety of input and output options.
© Sigmatek
By combining digital and analog I/Os in one module, users can save control cabinet space. The multi-I/O module has six digital inputs with an input current of 3.7 mA and an input delay of typically 0.5 ms. Eight digital outputs are also integrated, which are short-circuit-proof and designed for 0.5 A. The outputs can be read back and can also be used as inputs. In addition to the digital I/Os, an analog voltage input (±10 V(DC) with 16-bit resolution) and an analog current input are integrated. The latter is designed for measuring ranges from 0 to 20 mA or 4 to 20 mA with a resolution of 16 bits. The module can be programmed and configured using the object-oriented engineering tool Lasal.
Weidmüller
Back in automation with 'u-control'
After the connection technology specialist Weidmüller announced its re-entry into the I/O business in September 2013, the Detmold-based company is now expanding its u-remote system to include PLC functions and, in the future, drive technology.
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
SPS 2024
Automation meets innovation
SPS - Smart Production Solutions will take place in Nuremberg from November 12 to 14. Once again this year, organizers and exhibitors will pick up on the trends in the automation industry and present suitable solutions. The introduction of IT into...
