Wiring
Building installation with push-in three-pole terminal blocks
The PTI 4 three-prong installation terminal blocks with push-in connection technology from Phoenix Contact allow rigid conductors up to 6 mm² to be wired directly and without tools.
The terminals in a compact design are specially tailored to the requirements of electrical installation and distribution board construction. Latching screwless disconnect slides with status display make contacting the neutral conductor busbar easy and safe. The function shaft on each level ensures simple potential distribution with the flexible jumper system. Each terminal point can be clearly marked and has its own test tap in addition to the test option in the function shaft. Rigid and flexible conductors with ferrules from 0.5 to 6 mm² can be plugged in without tools. The built-in actuating pusher enables fully insulated disconnection with any tool. The orange color of the pusher identifies it as an actuating element. Flexible conductors without ferrules from 0.2 mm² can also be connected by pressing the push-button. The three-pin terminal blocks have all the system features of the 'Clipline complete' terminal block system.
