Drive technology
Günter Herkommer,
TQ-Group announces its own servo inverters
The TQ Group, based in Seefeld near Munich, has announced that it will be launching its own servo inverter technology under the RoboDrive brand at the end of 2016.
At the upcoming Motek trade fair in Stuttgart (October 10 to 13), TQ will be presenting the new servo inverters at the joint "Mechatronics & Automation Cluster" stand (Hall 8, Stand 8510).
© TQ-Group
The planned, universally applicable SDB-40-100 low-voltage inverter will for the first time make it possible to exploit the full dynamic potential of RoboDrive motors and thus, for example, optimize process cycle times and perfect synchronization characteristics. The inverter supports all standard sensor types and fieldbuses. In addition, TQ has paid particular attention to the fact that all axes can be synchronized in the nanosecond range, even in networks with a three-digit number of participants.
According to the manufacturer, the TQ computing module enables all control loops to be clocked at 100 kHz without exception. This would make it possible, for example, to modulate Beethoven's 9th Symphony in clear D minor using the current controller. In terms of drive technology, the control dynamics are sufficient to operate motors at speeds of up to 600,000 rpm with clean sine commutation.
The enormous speed dynamics can be seen in a speed inversion from negative to positive maximum speed, which takes place so quickly that it is not visually perceptible. This inversion means a speed change of more than 50,000 rpm in just under 10 milliseconds, so that the resulting jerk of the rotor, which weighs just 8 grams, can be felt very clearly with the human hand.
With the extraordinarily short controller clocks, TQ has taken the necessary step to make classic oscilloscopes superfluous during commissioning. In addition to the usual status variables, digital data logging also makes all internal controller variables available directly on the PC with a time resolution of 100 kHz.
Congress event
'Human Robot Forum' in Stuttgart
Cooperation between humans and robots - HRC for short - is considered one of the main pillars of Industry 4.0. But how can HRC be implemented economically in SMEs? The 'Human-Robot Forum', which takes place in Stuttgart from October 17 to 18,...
In focus: HMI
The e-paper of issue 06/23
How can digitalization and artificial intelligence help to make production processes sustainable? How can cobots and automated guided vehicles bring variety to everyday working life and how can they support people? Starting points in this issue.
TQ
Four new module series
There are four new module series from TQ: TQMa243xL, TQMa64xxl, TQMa117xl and TQ110EB. TQMa243xL and TQMa64xxL (image) are pin-compatible with each other and are based on the Sitara AM243x and AM64xx series from Texas Instruments.
