Analog Devices
Jeff DeAngelis | Andrea Gillhuber,
The next stage of evolution
In the future, machines will adjust their performance parameters independently with the help of AI-based observation algorithms. The value of a self-learning machine lies in its ability to maximize productivity, extend service life and reduce maintenance costs.
© Astibuag/stock.adobe.com
The term 'self-aware' describes a system that assesses itself based on an understanding of its own capabilities and desired system behavior. In fact, self-aware propulsion technology requires the implementation of multiple control loops that interpret sensor inputs and desired system parameters, as well as the ability to compare their own operating behavior with the desired system performance. To achieve these goals and develop self-aware propulsion technology, we need an adaptive control unit that monitors the system response and dynamically adjusts its own behavior based on the current drive load range.
In this article, we would like to present an approach for a self-aware propulsion system that uses an autonomous control unit to recognize and monitor the constantly changing operating conditions. These conditions are derived from a series of nested, real-time control loop models that use the motion parameters of the drives at field level. Once an electrical and mechanical model of the drive system is created, it is used to compare and adjust the system performance required at the monitoring, planning or management level of the automation pyramid (Figure 1). When a new desired system behavior is requested from any level above the supervisory level of the automation pyramid, a set of new control parameters is transmitted to the drive's adaptive control unit. The system then adapts its behavior to meet the new performance requirements.
The automation pyramid.
© Analog Devices
The two main advantages of self-aware drive technology are its ability to self-regulate and to maximize performance in real time. This new capability offers the monitoring, planning and management levels of the automation pyramid the opportunity to increase the performance of a self-aware drive system by adapting it. In addition, an AI-powered software algorithm can be used to adjust the overall system behavior to achieve a better plant-wide result. To better understand the four basic elements required for implementation, let's take a closer look with a concept map.
Concept of a self-aware drive unit
Figure 2: Concept map for a self-learning motion control system.
© Analog Devices
To implement this level of self-aware drive technology, we need to create a concept for the control system. Figure 2 shows the four key elements required for a successful implementation:
Element I - Goal or task: A clear goal or task must be defined for the system to accomplish. In our example, this means: "Move the beer mug from point A to point B in the best possible way so that no beer is spilled."
Element II - Desired system behavior: Once this goal is established, the next level of self-aware control initiates the desired movement behavior. For our beer mug example, this would be: "Use a linear motion to move the beer mug and automatically adjust the motion to compensate for the fluctuating weight and size of the beer mug within the required safety limits of the mechanical system."
Figure 3: Monitoring and automatic tuning of torque, flux, current, speed and position control loops.
© Analog Devices
Once the target and the desired system behavior have been defined, the adaptive control system ensures dynamic convergence between the kinematics of the core system and the associated mechanical system by automatically tuning the drive and the integrated mechanical system to achieve maximum operating performance in the respective working point (Fig. 2).
Element III - Core drive system: The heart of self-aware drive technology is its kinematics. The challenge is to observe, learn from and monitor the performance of the motor and drive system. To create a working model of the drive system, an intelligent observer must be implemented to gain a basic understanding of the motion parameters and the physical limits of the drive system. This is achieved through field-oriented control (FOC) with dedicated position sensors or a sensorless FOC approach to learn how the motor is loaded and reacts in its operating environment. By monitoring and automatically tuning the control parameter values from the control loops for torque, magnetic flux, current, speed and position of the motor, we can optimize the response of the drive system. Once these datagrams are collected and fed to the intelligent observer, the implemented optimization algorithm ensures that the motion control parameters are calculated and the underlying control algorithm converges to an optimal set of motion parameters (Figure 3). Now that an intermediate motion model has been created to model and optimize the motion of the drive system, the next stage of self-aware drive control can be implemented by introducing an adaptive control engine.
Figure 4: Adaptive control model.
© Analog Devices
Element IV - Adaptive control: Building on the kinematics and FOC autotuning capability of our system, we now focus on the next stage of implementing self-aware control, the adaptive control engine. This next level of intelligent drive focuses on communicating the desired system behavior to the adaptive control engine (Figure 4). This system behavior is provided by a production worker, the plant supervisor or by an AI productivity algorithm that collects plant data using its network of smart sensors. Once the desired behavior is passed to the adaptive control engine, the self-aware controller begins to dynamically reconfigure the operating parameters of the drive system to achieve the desired system behavior. Some examples of these desired behaviors are the requirement to increase production throughput or to extend the life of the motor by operating at safe operating points. While the motion controller automatically adjusts its parameters to achieve the new required performance level, the adaptive controller continuously monitors the closed loop to maintain the desired performance level. This state is maintained even if the drive system is subject to changes due to wear of the mechanical systems or if the operating conditions of the motor change. The system has now reached the highest level of self-aware drive control.
Practical example of beer transportation
Figure 5: Example of a self-learning motion control system in action (variable weight load).
© Analog Devices
The technology of a self-aware control system is currently being optimized for industrial use. One can imagine an entire factory based on devices with self-aware motors and intelligent sensors. This plant would have the ability to self-correct potential equipment failures, automatically adjust production processes to maximize productivity and extend equipment life throughout the manufacturing process.
The author: Jeff DeAngelis is Vice President of Industrial Communications and Motion Control, Industrial and Healthcare Division at Analog Devices.
© Analog Devices
The best way to illustrate this concept is with a real-life example (Figure 5). Let us now look at an example of the implementation of a self-aware control system: The aim of this task is to bring a glass of beer from the bartender (point A) to a customer at the other end of the bar (point B) in the fastest possible time without spilling a drop of beer. The equipment system in this case is a cup holder with a built-in weight sensor that detects the weight of the different sized beer mugs and moves them along the length of the bar using a linear motor. A self-aware drive system is beneficial to get the beer to the customer as quickly as possible, but it can also automatically adjust its speed and power when the customer places the empty or partially empty beer mug in the cup holder to return the beer mug to the bartender or have it refilled. This system also offers the possibility to adjust its behavior when the bartender uses glasses of different sizes for different types of drinks.
Schaeffler
At its meeting on September 26, Schaeffler's Supervisory Board made two appointments to the Executive Board. There is also another change in the Executive Board. As a result, the Executive Board will consist of nine members from October 1, 2024...
