Festo
Pneumatics makes technological leap
With Festo's 'Controlled Pneumatics' compressed air technology, the 'VTEP' proportional valve terminal achieves sensitive pressure control down to less than 1 mbar. According to the supplier, the technology also uses piezo valves to reduce compressed air consumption by up to 50 %.
© Festo
At less than 120 mm wide, the proportional valve terminal is the most compact proportional valve terminal for pressure control with ten working channels on the market, according to Festo. It can be easily integrated for multi-channel applications - in two-, three- or five-channel versions. Pressure and vacuum can be combined in the control range of 6 bar. The directly controlled valve terminal uses piezo technology, which makes the pneumatics highly precise, fast and economical with the appropriate control technology. The valves are therefore noiseless, wear-free, without particle abrasion or heat generation. In addition, the valve terminal is free of copper, nickel and zinc, making it suitable for battery production and other industrial segments in which these materials are not desired.
With 'Controlled Pneumatics', Festo combines proportional technology, sensor technology and control algorithms to form a control loop. This technology opens up new fields of application for pneumatics in terms of pressure, flow and movement - and, according to the supplier, also makes conventional production more efficient. Last but not least, the high-precision piezo valves reduce the consumption of compressed air by up to 50%, as it can be perfectly metered.
Festo
Autonomous flying in a swarm
The 'BionicBee' is an ultra-light flying object from Festo that can fly in large numbers and completely autonomously in a swarm. The BionicBee performed its first air show at the Hannover Messe 2024.
Festo
Honored with the German Sustainability Award
The German Sustainability Award in the hydraulics, pumps and compressors category went to Festo in 2023. The award is based on the goals of Agenda 2030 and thus on key areas of transformation such as climate, biodiversity, resources, supply chain...
Festo
Inspired by nature
Automation technology performs tasks such as gripping, moving and positioning goods as well as controlling and regulating processes in everyday factory life. Nature solves such tasks 'by the way'. So why not look at its phenomena and learn from them?
Festo
Hanover Fair
E-Paper: HANNOVER MESSE DAILY Day 2
In today's issue, you can read about the tour of the trade fair by German Chancellor Olaf Scholz and the Prime Minister of the host country Norway, Jonas Gahr Støre, the partnership between Festo and Phoenix Contact and the demands of the...
Most read
The top articles in March 2024
New technological developments lead the most-read articles in March. Motors that redefine energy saving, a plastic wheel that discovers the road, a new Ecolabel and, last but not least, the arrival of ChatGPT in the industry. Read for yourself.
