Geared motors
Quelle: WEG Germany | Inka Krischke,
Nominal torques from 50 to 600 Nm
The WG20 geared motor range from WEG includes helical, parallel shaft and helical bevel gearboxes with die-cast aluminum housings for rated torques from 50 to 600 Nm.
© WEG Germany
The geared motors are available in energy efficiency classes IE2 and IE3. The first geared motor range under the WEG brand is based on Watt Drive's development and manufacturing expertise and combines this with WEG's motor know-how and global sales and service network. Thanks to the standard connection dimensions, the geared motors can be used in both newly developed and existing systems worldwide. The modular gear add-on motor also facilitates interchangeability, as it covers almost all global voltages thanks to the motor's internal voltage changeover. The geared motors have a two-stage design with a large reduction range and, according to the manufacturer, generate only low energy losses.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
