Ebm-papst at the Motek 2023
Annina Schopen | Andrea Gillhuber,
Motor for individual drive systems
At Motek, ebm-Papst will be presenting new drive solutions, such as the modular drive system, for automation in a new performance class.
© ebm-Papst
ebm-Papst has now expanded its existing ECI drive series to cover even higher outputs in automation. The new BLDC motors based on the internal rotor principle in safety extra-low voltage (24 / 48 VDC) with a diameter of 80 mm and a rated output of up to 750 watts can be individually combined with different modules to form a complete drive system. Housed in a robust metal housing, it meets the requirements of protection class IP54 as standard. The modular drive system includes planetary gearboxes with different reduction ratios as well as encoder and brake modules. Hall sensors for rotor position detection are currently integrated for operation with a remote drive controller; further electronic modules that can be integrated, such as speed or position controllers with optional bus interface, will follow.
Modular system enables individual drive systems
Long waiting times for the perfect drive system were not uncommon in the past, as individual solutions often had to be developed first. With the modular drive system from ebm-Papst, drive solutions can now be implemented quickly and individually. The individual drive modules can be put together using standardized interfaces. Similar to a modular system, it is possible to assemble the motor with the appropriate power, brake, encoder, electronics and planetary, helical or angular gearbox online in a short time.
EtherCAT combines the advantages of Ethernet-based communication with the simplicity of classic fieldbus systems, which means that complex IT solutions can be avoided. Within the ECI series, drives with an integrated bus interface, for example in the size 63 modular drive system, are already established under the term K5 electronics functionality. Now the internal rotor motors can also be addressed via EtherCAT. High-performance interface electronics have been added to the drive housing for this purpose. According to the manufacturer, the main advantages for decentralized drives are the synchronization of several axes, the reduced integration effort and a space-saving design in the machine.
Motek 2023: Hall 7, Stand 7317
ebm-Papst
Investments in Singapore and India
ebm-Papst is investing around 1 million euros in the expansion and conversion of its site in Singapore. The original headquarters of the Southeast Asia region will in future manage the entire Asia-Pacific and Middle East Asia region.
Festo
Inspired by nature
Automation technology performs tasks such as gripping, moving and positioning goods as well as controlling and regulating processes in everyday factory life. Nature solves such tasks 'by the way'. So why not look at its phenomena and learn from them?
Lean technology
Easy to implement
SPS 2024
Automation meets innovation
SPS - Smart Production Solutions will take place in Nuremberg from November 12 to 14. Once again this year, organizers and exhibitors will pick up on the trends in the automation industry and present suitable solutions. The introduction of IT into...
