Linear guides
Quelle: Bosch Rexroth | Inka Krischke,
Measurement accurate to ±4 µm
The IMS-A measuring system from Rexroth integrated into linear guides records the absolute position of the axis to an accuracy of ±4 µm and reports it to the controller without the need for a reference run.
© Bosch Rexroth
The measuring system is insensitive to dirt, vibrations, shocks and magnetic interference fields and does not require backup batteries during a power failure. Additional temperature and motion sensors are installed in preparation for future Industry 4.0 requirements. Thanks to the inductive measuring principle, the system is contactless and wear-free. The measuring scale cannot be disturbed or destroyed by external magnetic fields. The sensors and evaluation electronics are protected in a housing on the front of the carriage. The position resolution of the measuring system is up to 0.025 µm.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
