Rollon
Linear technology and digitization
Rollon and Nadella, both members of the Timken Group, exhibited linear technology products for intelligent automation and robotics at SPS. The iAXNR oval system combines linear technology with sensors for monitoring vibration and temperature.
© Rollon
Their data is processed locally by an edge computing system. The collection and analysis of sensor data can help to identify areas where performance can be improved and production processes optimized. The continuous measurement and processing of data also makes proactive maintenance easy to implement. Vibration monitoring makes it possible to check whether the carriages and/or the indexing system are functioning correctly. If abnormal vibrations occur, it is possible to respond with changes to the settings or maintenance work. Rollon 's smart system can also increase the level of safety for the working environment. Continuous temperature monitoring also makes it easy to detect deviations from normal conditions and take action.
