Bosch Rexroth
Linear motor modules added to the portfolio
Bosch Rexroth is launching linear motor modules (LMM) onto the market. Available in sizes 140, 180 and 220, the axes with backlash-free direct drive are available in all sizes with iron-core linear motors.
© Bosch Rexroth
Sizes 180 and 220 LMMs from Bosch Rexroth are also available with an optional ironless motor. This opens up a wide range of applications with standard strokes of up to 1540 mm and forces of up to 2400 N. At maximum speeds of 5 m/s and maximum accelerations of 250 m/s2, the LMMs achieve a repeat accuracy of ±1.0 μm. The integrated spindle-free direct drive replaces mechanical power transmission, which increases dynamics and efficiency and enables high-precision repeatability. At the same time, the modular design of the ready-to-install LMM reduces assembly work.
Oriental Motor
For predictive maintenance
According to the manufacturer, the new incremental encoder from Oriental Motor is particularly suitable for use in predictive maintenance thanks to its precision in measuring speed, position and direction of rotation.
