Bosch Rexroth
Günter Herkommer,
Industry 1.0 meets Industry 4.0
What does a lathe from the year 1887 have to do with a high-tech industrial automation show like SPS IPC Drives? The Bosch Rexroth booth presented the answer.
Steffen Haack, Bosch Rexroth: “Our IoT gateway links to an Industry 4.0 environment without intervening in automation logic.
© Computer&AUTOMATION
It is 129 years old, pedal-operated, and an outstanding example of Industry 1.0 – the cast-iron lathe weighing 300 kg that Rexroth has brought along to Nuremberg for this year‘s show. In those days it cost 507 marks, the equivalent of 30,000 euros or more today. In other words: “Machines were already a big investment in those days, and still are“, says Dr Steffen Haack of the Bosch Rexroth executive, adding, “Consequently we must make as efficient use of them as possible. Networking with other machines and higher-level systems supports us decisively in doing that.“
But many machines in trade and industry still have no Industry 4.0 tie-up. They lack things like sensors, software or connection to corporate IT systems, and thus essential requirements for networked manufacturing. In Germany alone, reckons Haack, it concerns some tens of million machines. In part as a retrofit solution Rexroth has thus developed its own IoT gateway, presented at SPS IPC Drives for the first time, and catapulting the lathe into the age of Industry 4.0.
The hardware of this IoT gateway, consisting of an IndraControl XM, is IP20 graded for control cabinet installation. The software running on this is based on the Linux operating system. With the integrated Java virtual machine, Java-based applications and corresponding cloud services are developed through an OSGi framework. Different Java apps for typical application scenarios are provided by the IoT gateway for fast implementation. A web-based dashboard gives the user a detailed overview of collected data of the devices app in realtime. Sensor and process values can then be readied in the processing app and forwarded to different IoT services for data capture and analysis. The supported sensor spectrum ranges from digital and analog interfaces based on the scaled I/O portfolio IndraControl S20 through Bluetooth low energy to USB and RFID.
At the Hanover Fair Rexroth already presented the WebConnector, a further component for linking automation to the IoT. Asked about the difference from the IoT gateway, Haack answers: “WebConnector focuses on web-based visualization of a machine. But the IoT gateway serves as a plug&play solution for simple capture of process variables and parameters of a machine in realtime to forward them to higher-level systems for analysis.“
The new IoT gateway comes both standalone and as part of a customized i4.0 upgrade kit from Bosch Rexroth including, for example, extra IoT-based solutions of Bosch Software Innovations, like the production performance manager. The software collects the information in a visualization, and forwards specified events to defined persons. Communication can also work by the machine language PPMP (production performance management protocol) recently presented by Bosch. This protocol, linking machines to corporate IT, concentrates on the essential content of a message without unnecessarily increasing complexity of implementation. “Publishing code through Eclipse makes things transparent, characteristics that count, what data make sense in use for networking,“ explains Haack.
Start-ups
The 'Automation Hackathon'
At the 'Automation Hackathon' at SPS IPC Drives 2018, seven start-ups had the chance to develop new business models for selected companies in the automation industry in 48 hours. Winner: the start-up Othermo in collaboration with Wago.
Synapticon
Entering the Machine Building Business
Known as a technology supplier to robot manufacturers, Synapticon now plans to offer targeted solutions for machine builders. The kick-off was given at the SPS IPC Drives with the ‚Actilink‘ drive systems and a quick-start package for the production...
Faulhaber
The winding does it!
With the market launch of the new brushless DC motor family BXT, Faulhaber is setting new standards in the field of external rotor high-performance drives. The winding plays a central role in this.
