Ship drives
Quelle: ABB | Inka Krischke,
Increased fuel efficiency
Azipod XL, the latest model of ABB's electric ship propulsion system, increases the fuel efficiency of ships by 20% compared to modern shaft drive systems, according to the supplier.
© ABB
This increase in efficiency is achieved by a nozzle system that accelerates the flow of water into the propeller in order to increase thrust. In addition, the thruster has been redesigned to reduce water resistance. The 'Azipod' propulsion system is a gearless, steerable propulsion system in which the electric motor is mounted outside the hull in a submerged nacelle. With the drive rotating through 360°, it is used simultaneously for both steering and propelling a wide variety of ships. The Azipod-XL concept can be designed to achieve high thrust at lower speeds while maintaining good performance characteristics at higher speeds. The drive is therefore suitable for tugs and offshore construction vessels as well as ferries and LNG tankers. The drive also allows the system status to be monitored. The concept of the 'Internet of Things, Services and People' - IoTSP for short - and ABB's integrated 'Marine Operations Center' are used for this purpose.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
