SPN Schwaben Precision at the SPS 2022Spur gearbox for float drive
SPN Schwaben Präzision has developed a spur gear for a float drive in partnership with a customer in the mechanical engineering sector.
3 of 11
© Dr. Fritz Faulhaber
Faulhaber has expanded the BXT flat motor series to include gears and integrated encoders and speed controllers that are also unusually short in the axial direction, according to the manufacturer. Typical applications for the compact drive systems include robotics, prosthetic joints, laboratory automation, pumps, medical technology and aircraft cabin equipment. Thanks to special winding technology and optimized design, the motors themselves are only 14, 16 and 21 mm long, but deliver torques of up to 134 mNm with diameters of 22 mm, 32 mm and 42 mm respectively.
For precise speed control or where high positioning accuracy is required, diameter-compliant magnetic encoders or speed controllers are fully integrated into the housed motor variants, increasing the length of the drive by just 6.2 mm. The matching metal planetary gearboxes from the GPT series also offer a short design, high torque and fine gradations of the numerous reduction ratios.
SPS 2022: Hall 4, Stand 346
3 of 11
