SPS IPC Drives 2016Siemens moves Mindsphere platform into focus
Under the motto "Driving the Digital Enterprise", Siemens will be presenting specific applications for the digital factory at SPS IPC Drives. A new special area is dedicated to the IoT ecosystem 'Mindsphere'.
© Siemens
With the Sitrans TO500, Siemens is launching an innovative measuring system for fiber optic temperature measurement. It is designed to enable complex temperature measurements and the precise detection of critical temperature overshoots, for example in tube and tube bundle reactors. According to the manufacturer, the measuring system is characterized by a large number of measuring points (up to 48 per measuring lance, depending on the temperature range) and a small diameter of the sensor measuring lance.
