Take part and winProducts of the year 2023 - your vote counts!
96 products in 12 categories are up for election for the "Products of the Year 2023"! Take part and win Saturn vouchers worth €500, among other things!
4 of 9
Products of the Year 2023 - Nominated in the Measurement Technology category: ipf electronic
© ipf electronic
ipf electronic - Measuring transducer for the top-hat rail
With the BA870100, ipf electronic presents a programmable or configurable measuring transducer in a DIN rail housing for simple processing of analog values. To connect a variety of possible input signals, the transmitter integrates two optionally linkable analog inputs, either voltage or current (0 to 10 V, 4 to 20 mA, 0 to 20 mA), with freely selectable units as well as an external teach input with optional zero-point function. A total of four digital outputs and a scalable analog output, which can be used as a voltage and current output (0 to 10 V, 4 to 20 mA), are used to pass on the signals. The outputs can be assigned to any input as required. A 10-bit A/D converter ensures the appropriate resolution of the required signal. It is also possible to switch the output signals in any desired form (NPN/PNP, normally closed/ normally open function, time functions). Configuration takes place via the intuitive operating concept, using three pushbuttons to navigate through the operating structure on the color TFT display.
>> Go directly to tuning!
4 of 9
