Take part and winProducts of the year 2023 - your vote counts!
96 products in 12 categories are up for election for the "Products of the Year 2023"! Take part and win Saturn vouchers worth €500, among other things!
2 of 9
Products of the Year 2023 - Nominated in the Embedded Computing & IPC category: Kontron
© Kontron
Kontron - For data-intensive IoT Edge and AI applications
With the KBox A-151-TGL, Kontron is launching an industrial computer in box PC format for demanding IoT Edge or AI applications. The computer is based on the 11th generation Intel Core i3-1115G4E, i5-1145GRE/i5-1145G7 or i7-1185GRE/i7-1185G7E or the Intel Celeron processor 6305E with up to four computing cores and 4.4 GHz (burst) each as well as a maximum memory expansion of 64 Gbytes. In addition to two display ports and two Gigabit Ethernet interfaces, including a 2.5 GbE interface with TSN functionality, there are also four USB 3.2 and two RS232/422/485 interfaces. Using the three M.2 expansion slots, which can be used for the integration of NVMe SSDs as well as fieldbuses and wireless technology such as 4G/5G or WiFi 6 connectivity, the system can be expanded with a wide range of functionalities. The majority of system expansions are made accessible via an expansion slot (I/O door) on the front of the system. The Kontron industrial computer can be operated in the range from 0 to +60 °C or optionally in the extended temperature range between -40 and +60 °C.
>> Directly to the vote!
2 of 9
