Take part and winProducts of the year 2023 - your vote counts!
96 products in 12 categories are up for election for the "Products of the Year 2023"! Take part and win Saturn vouchers worth €500, among other things!
3 of 9
Products of the Year 2023 - Nominated in the Electromechanics category: Tsubaki Kabelschlepp
© Tsubaki Kabelschlepp
Tsubaki Kabelschlepp - Protecting cable carriers and cables
The active pull-back unit (PBU) from Tsubaki Kabelschlepp ensures that 'Robotrax' cable carriers are safely guided and deposited. The background to this development is a well-known problem in automated production processes: With fast movement sequences and large workspaces, the relatively long cable carriers strike the robot arm. The 'pull-back unit' prevents this by keeping the cable carrier under tension. Premature wear therefore does not occur, the service life is extended and expensive downtimes are avoided. The compact design of the unit results in fewer interfering contours and a lower risk of collision. The 'PBU' can be used in robots regardless of size, manufacturer and type and is also suitable for retrofitting and modernizing existing work cells. Standard mountings are available for robots from Kuka, ABB and Fanuc. The return unit can be mounted vertically, horizontally or overhead; the extension length is 350 mm.
>> Go directly to the vote!
3 of 9
