Sieve & Meyer
Drive high-speed motors dynamically
Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications under the name SD4x. It starts with the SD4S version, which is designed for small high-speed spindles and motors with outputs of just a few 100 W.
Torsten Blankenburg, Sieb & Meyer: "Our aim is to drive high-speed motors dynamically and with as little power loss as possible."
© Sieve&Meyer
The SD4S is the first member of the SD4x frequency inverter family from Sieb & Meyer.
© Sieve&Meyer
The new frequency inverters support interfaces and protocols such as Profinet, TNC or BiSS. Their central feature is the significantly improved processor performance: the built-in 32-bit ARM Cortex M7 processor from NXP is up to five times faster than the processors of the SD2x frequency inverters and therefore allows a higher resolution and more precise calculations. Sieb & Meyer has also switched from fixed-point to floating-point arithmetic, which allows for a more flexible design. "Overall, more complex tasks can be processed faster with the new processor system," says Torsten Blankenburg, Chief Technology Officer at Sieb & Meyer. A new FPGA from the "Spartan-7" product line from Xilinx is also integrated: it enables more complex control tasks to be processed. Sieb & Meyer has also significantly increased the memory compared to the members of the SD2x family - "with 500 times more memory, there will be no bottlenecks in the foreseeable future," says Blankenburg. "For the customer, this means a significant increase in performance: higher switching frequencies and improved control quality at even higher speeds result in improvements in the overall process."
Thanks to an integrated position controller, the SD4x devices can also perform high-precision positioning independently; speed and current controllers remain constant compared to the SD2x series. "Our aim is to drive high-speed motors dynamically and with as little power loss as possible," explains Blankenburg. "That's why we now also support PWM switching frequencies of 24 and 32 kHz." For even finer modulation of the sinusoidal signal, commutation angle control is now also integrated for 32, 48 and 64 kHz. "This results in an almost optimal sine wave, there are virtually no more harmonic currents," notes Blankenburg.
Usability has also been improved: the new "drivemaster4" version of Sieb & Meyer's parameterization software offers a four-part user interface. A watchlist makes it possible to subscribe to the parameters of several devices at the same time - "this is particularly useful for multi-axis applications", explains Blankenburg. A data logger also allows users to view and evaluate characteristic curves over longer periods of time.
The SD4S is designed for small high-speed spindles and motors in the power range of a few 100 W. Examples of applications include dental milling machines or machines for precision machining, such as those required in the watchmaking industry. Because the necessary insulation strength is often not provided in the motors of small spindles, the SD4S now enables galvanic isolation of the thermal contact. Blankenburg considers the width of just 40 mm to be an "absolute novelty".
Parameterization is carried out via a standard Ethernet interface, which replaces the USB interface that is prone to interference in industry. The SD4S also has parameterizable digital measuring system interfaces such as BiSS-C, EnDat2.2 and TTL. A web server enables technicians to call up device information without additional parameterization software. The real-time clock can be used to synchronize the time of an incident: for example, users can find out whether a thunderstorm has caused a failure.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
