Nasa electric aircraft X-57
Davina Spohn,
14 Propellers instead of two
As part of the 'X-Plane for Experimental Aircraft' program, researchers at the US space agency NASA are working on an aircraft that does without combustion engines and is powered purely by electricity: with a multi-propeller system integrated into the wing.
xxx
© Nasa Langley / Advanced Concepts Lab, AMA, Inc
Exoskeleton
Electric motorcycle from the 3D printer
Airbus subsidiary APWorks demonstrates the possibilities of additive manufacturing: its electric motorcycle 'Light Rider' has an exoskeleton-like chassis from the 3D printer that weighs just 6 kg. Thanks to its material, the motorcycle is extremely...
NASA
Hüpfender Roboter für Kometen-Erkundung
Bei der Landung auf fremden Himmelskörpern kann es holprig zugehen, wie die Esa-Kometensonde 'Philae' Ende 2014 unfreiwillig demonstrierte. Jetzt präsentiert die Weltraumbehörde NASA den Roboter 'Hedgehog', der extra für Landungen auf rauen...
